Chery Cowin 3 (A5) & Chery E5 - Page 19 - China Car Forums
Go Back   China Car Forums > Chinese Car Manufacturers > Chery
Reply
Thread Tools Display Modes
Old 03-16-2020, 04:44 AM   #181
Omar
Junior Member
Default Chery A520 Automatic Tranmission Issue
i have the DP0 AL4 automatic transmission 2009 patch. and i faced overheating issue. the technician pulled out 2L from the gearbox.
but there's a recommendation to replace the DEXRON III based oil (Mobil ATF 320) with LT71141 based oil as Mannol AG52 or Mobil ATF LT71141 as this oil doesn't get hot as the Dexron III so it avoids the overheating issue.
I read about some piece in this early patch of DP0 getting affected by the high temperature of the DEXRON III based oil so Some use LT71141 based oil to extend its life span as the oil doesn't reach high degrees of temperature.
I'm worry because these are totally two different types and specs, so it can cause a huge mechanical problem to the gearbox if i used LT71141 oil.
My question is:
What should i do? replace the DEXRON III oil with LT71141 oil? or there's something more appropriate to to?
Omar is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-13-2020, 03:09 AM   #182
Omar
Junior Member
Default Re: Chery Cowin 3 (A5) & Chery E5
up ..
Old 04-13-2020, 09:11 AM   #183
dmitra
CCF Mod
See this page, especially the section in green "Oil and filter change":
https://marshalinstrument.ru/en/akku...iya-al4-samoe/
dmitra is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
