ZX Auto S1 (BQ7151A) - China Car Forums
Go Back   China Car Forums > Chinese Car Manufacturers > Zhongxing (ZX Auto)
Reply
Thread Tools Display Modes
Old 04-14-2020, 02:51 PM   #1
dmitra
CCF Mod
Default ZX Auto S1 (BQ7151A)
New (coupe?) SUV, probably based on the underpinnings of the defunct GX3. Width and wheelbase are 1760 and 2512 mm, reasonably in close agreement with corresponding dimensions of the GX3 (1761 mm and 2500 mm), although somewhat longer overall at 4223 mm (GX3: 4160 mm). It is powered by a 1499 cc, 80 kW (109 PS) engine. The name of the vehicle is illegible from the small and low-res pictures published on the MIIT site (appears to begin with an "S").
The new SUV will be produced at ZX Auto's new plant in Rizhao, Shandong, that was inaugurated last December and currently builds the Terralord.
http://www.miit.gov.cn/datainfo/viewCar?carId=287744#
dmitra is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-15-2020, 09:11 AM   #2
erik (laofan), cmvdc
erik (laofan), cmvdc's Avatar
Default Re: ZX Auto BQ7151A
This is quite a surprise.
Erik
www.chinesecars.net
erik (laofan), cmvdc is offline   Reply With Quote
Old 06-05-2020, 02:49 AM   #3
dmitra
CCF Mod
Default ZX Auto S1 "Coupe"
From MIIT's Fuel Consumption Inquiry table, I learned that the BQ7151A is going to be known as "S1" (中兴ĚS1).
On doing a little more investigation, it turns out that ZX Auto is planning to launch a total of 4 passenger vehicles, on two platforms*, among which the S1 will come in two versions: a "sport" version and a "travel" version. The "sport" version is the one pictured above, and since "sport" SUVs are sometimes also called "coupe", I looked again at the rear end of the car and the second word after S1 very much looks like "coupe". I am speculating that the "travel" [used to describe estates] version will very likely be a -- possibly longer -- variant of this body with a more conventional six-window SUV design, somewhat like the RR Evoque.
The other two passenger vehicles in the pipeline are tentatively known an "S3" and "A3". I guess the S3 will be another SUV sitting one or two segments higher. The welding line for the S3 has already been set up in Rizhao (link). I however cannot say what the A3 will be. I doubt they'll do sedans.
_________________________
*Referred to as 1-series and 3-series Passenger platforms.
Click image for larger version
Old 06-05-2020, 04:19 AM   #4
dmitra
CCF Mod
Default ZX Auto S3 (future SUV)
I have accessed some information on the S3 from an Environmental Impact Report on the Rizhao plant.
The provisional technical parameters are:
Dimensions: 4517 x 1875 x 1510 mm
Wheelbase: 2675 mm
Ground clearance: >=130 mm
Curb weight: <=1600 kg
Engine power: 83 kW/113 PS (fuel verison)
Motor power: 90 kW (electric version)
Torque: 141 Nm (fuel)/280 Nm (electric)
Battery capacity: 57 kWh (electric)
Range: 400 km (electric)
Transmission: 5-speed manual (fuel); single speed (EV)
Suspension: Independent (front)/non-independent (rear)
The S1, referred to in the document as Youth Edition (S1-青春版), has slightly different specs (dimensions, power) as compared to those published by MIIT, but that is expected. The S1 too will have an electric version, powered by the 90 kW motor, and battery capacity will be 48 kWh or more, giving it a range of at least 300 km.
The Rizhao plant has an annual production capacity of 50,000 vehicles (SUV+pickup) of which fuel-driven vehicles are allocated 10,000 and electric vehicles 40,000.
ID:	51271   Click image for larger version
ID:	51273   Click image for larger version
ID:	51275   Click image for larger version
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
