there is a bodykit for the chery A11, I don't know who makes it but it might be topmix. I know that shanghai jinbang have fitted some. they can do you a sports exhaust as well although I am not entirely satisfied with the frequency of failure of these backyard built exhausts.
anyone who can import suspension kits from overseas can get you a mk2 golf kit that fits the A11 - most people don't realise it's a direct fit but I can assure you it is because I've done it.
I got mine from china dragon racing in shanghai.
chery brakes aren't very good, mainly because they use a really village pad supplier. get yourself some ferodo pads or better still you can do a direct swap using santana 200 vented discs and the calipers from the old audi 100, it all bolts together directly and with decent pads it's a big improvement.
for the 8v engine in the fengyun, best bet is to get someone to turbocharge it for you - anyone like sam's in shanghai that has done lioncell's should be able to do it but I don't think anyone's done a chery yet. in theory you should be able to use the later 480EF pistons with the earlier 480E head to lower the compression ratio, but this is all on my to do list.
if you have the tritec engined flagcloud, then I don't see why you couldn't upgrade it to a supercharged spec using mini cooper parts, I heard that Eaton who make the supercharger have a running prototype somewhere.
for a bit of audio, you can install MDF panels into the rear shelf and then fit 6x9s, with an amplifier and good front speakers it works well, of course you want to be able to pull out all that extra weight quickly for track days.
