1.3L MPI LC
Technical Data:
Cylinder:4
Displacement(L):1.297
Bore×Stroke(mm):73x77.5
Rated Power(Kw/r/min):64/6000
Max. Torque(Nm /r/min) :118/3800
Compression Ratio:10
Overall Dimension(L×W×H):607x634x605
Net Weight(Kg):120
Code: 473F
SOP: 2006/03
Emission: EU Ⅳ
Feature: Inline, Water-cooling, DOHC, 16 Valves, Aluminum Alloy cylinder block and head, MPI
1.3L CBR VVT
Technical Data:
Cylinder:4
Rated Power(Kw/r/min):65/6000
Net Weight(Kg):120
Code: 473H
SOP: 2006/03
Emission: EU Ⅳ
Feature: Inline, Water-cooling, DOHC, 16 Valves, Aluminum Alloy cylinder block and head, MPI, VVT, CBR
1.6L CBR VVT
Technical Data:
Cylinder:4
Displacement(L):1.5974
Bore×Stroke(mm):81x77.5
Rated Power(Kw/r/min):87/6000
Max. Torque(Nm /r/min) :147/4300
Overall Dimension(L×W×H):641x634x638
Net Weight(Kg):147
Code: 481H
SOP: Yes
Emission: EU Ⅳ
Feature: Inline, Water-cooling, DOHC, 16 Valves, Aluminum Alloy cylinder block and head, MPI, VVT, CBR.
1.6L LC
Technical Data:
Cylinder:4
Rated Power(Kw/r/min):80/5800
Max. Torque(Nm /r/min) :144/4200
Net Weight(Kg):147
Code: 481F
SOP: Yes
Emission: EU Ⅳ
Feature: Inline, Water-cooling, DOHC, 16 Valves, Aluminum Alloy cylinder block and head, MPI.
1.8L
Technical Data:
Cylinder:4
Displacement(L):1.855
Bore×Stroke(mm):85.5X98.5
Rated Power(Kw/r/min):110/5750
Max. Torque(Nm /r/min) :110/5750
Net Weight(Kg):147
Code: 481FC
SOP: 2006/12
Emission: EU Ⅳ
Feature: Inline, Water-cooling, DOHC, 16 Valves, MPI, Cast iron cylinder block.
