41 - 60 of 90 Posts
Discussion Starter · #41 · (Edited)
Altulito said:
Firefox, can you please tell me where you found the engine specs? I'm doing a research paper for my master's. Are you sure the engines are EUR IV?
I'm so sorry Altulito, I nearly forgot this thread and it's today I checked it again since my last post
I found these photos at the Chery's official website for it's engines, here's the link: http://www.cheryacteco.com
Chery Power ACTECO Engine web site - (is this a repost?)
Chery Power ACTECO Engines web site:
(i cannot post URLs due to the admin's stupid rule - "You are only allowed to post URLs to other sites after you have made 10 posts or more.")
www (dot) cheryacteco (dot) com/index_en (dot) asp
Acteco 480 Gasoline Engines
Technical Data: Cylinder:4
Displacement:1.597
Rated Power:71/5500
Max. Torque:142/3000-3500
Compression Ratio:10
Code: SQR480
SOP: YES
Emission: EU Ⅲ, potential for Ⅳ
Displacement:1.349
Rated Power:62/5500
Max. Torque:115/3000-3500
Code: SQR475E
SOP: 2006.06
Acteco 72 Gasoline Engines
Technical Data: Cylinder:3
Displacement:0.812
Rated Power:44/6000
Max. Torque:84/3200
Compression Ratio:8.5
Code: SQR372
SOP: 2007.02
Displacement:0.812
Rated Power:38/6000
Max. Torque:70/3500-4000
Compression Ratio:9.5
Code: SQR372
SOP: YES
Displacement:1.083
Rated Power:50/6000
Max. Torque:90/3500-4000
Code: SQR472
SOP: YES
ACTECO NEF2 Gasoline Engines
Displacement:1.5974
Rated Power:80/6000
Max. Torque:144/4200
Name: 1.3L MPI LC
Code: SQR473F
SOP: YES
Emission: EU Ⅳ
Displacement:1.297
Rated Power:65/6000
Max. Torque:118/3800
Name: 1.3L CBR VVT
Code: SQR473H
SOP: 2006.10
Emission: EU Ⅳ
ACTECO NEF1 Gasoline Engines
Displacement:1.5974
Rated Power:80/6000
Code: SQR481F
SOP: YES
Emission: EU Ⅳ
Displacement:1.5974
Rated Power:87/6200
Max. Torque:147/4300
Name: 1.6L CBR VVT
Code: SQR481H
SOP: YES
Emission: EU Ⅳ
Displacement:1.971
Rated Power:125/5500
Max. Torque:235/1900
Compression Ratio:8.9
Code: SQR484B
SOP: 2006.10
Emission: EU Ⅳ
Displacement:1.971
Rated Power:144/5500
Max. Torque:290/1800
Compression Ratio:9.8
Name: 2.0 L TCI DGI
Code: SQR484J
SOP: 2008.01
Emission: EU Ⅳ
Displacement:1.971
Rated Power:104/5800
Max. Torque:186/4000
Name: 2.0L CBR VVT
Code: SQR484H
SOP: TBD
Emission: EU Ⅳ
Displacement:1.971
Rated Power:95/5750
Max. Torque:180/4200
Code: SQR484F
SOP: YES
Emission: EU Ⅳ
Technical Data: Cylinder:6
Displacement:2.394
Rated Power:130/6000
Max. Torque:223/3800
Compression Ratio:10.5
Name: 2.4L CBR VVT
Code: SQR681V
SOP: TBD
Emission: EU Ⅳ
Displacement:2.957
Rated Power:146/5500
Max. Torque:278/3800
Name: 3.0L CBR VVT
Code: SQR684V
SOP: 2007.7
Emission: EU Ⅳ
ACTECO NEFD Diesel Engines
Displacement:1.298
Rated Power:60/4000
Max. Torque:171/2000
Compression Ratio:17.5
Code: SQR381A
SOP: 2007.10
Emission: EU Ⅳ
Displacement:1.904
Rated Power:67/4000
Max. Torque:210/2000
Code: SQR481G
SOP: TBD
Displacement:1.904
Rated Power:48/4000
Max. Torque:130/2000
Code: SQR481D
SOP: TBD
Displacement:1.904
Rated Power:93/4000
Max. Torque:271/2000
Code: SQR481A
SOP: 2007.01
Emission: EU Ⅳ
Displacement:2.857
Rated Power:136/4000
Max. Torque:396/2000
Name: 2.9L V6 TCI
Code: SQR681R
SOP: TBD
Emission: EU Ⅳ
ACTECO NEF3 Gasoline Engines
Displacement:1.5974
Rated Power:90/6200
Max. Torque:148/4300
Code: SQR481FD
SOP: 2006.06
Emission: EU Ⅳ
Displacement:1.855
Rated Power:125/5750
Max. Torque:245/4300
Code: SQR481B
SOP: 2007.08
Emission: EU Ⅳ
Displacement:1.855
Rated Power:97/5750
Max. Torque:170/4300
Code: SQR481FC
SOP: 2006.10
Emission: EU Ⅳ
Displacement:1.971
Rated Power:101/5750
Max. Torque:180/4300
Code: SQR484FC
SOP: 2006.10
Emission: EU Ⅳ
Displacement:2.262
Rated Power:110/5750
Max. Torque:210/4300
Code: SQR486FC
SOP: 2007.04
Emission: EU Ⅳ
ACTECO Transmissions
Technical Data: Max. Input Torque(NM):130
Distance between input and output shaft(mm):68
Distance between final drive shaft(mm): 110
Distance between input shaft and differantial(mm):169
Length(mm):325
Width(mm):446
Height(mm):410
Weight(kg):30/31
Driving Shaft:Inserted
Drive Form:FF
SOP: 2006/04
Utility Scope: mainly match with 1.3-ltr.or smaller engine
Technical Data: Max. Input Torque(NM):190
Distance between input and output shaft(mm):72
Distance between final drive shaft(mm): 117.149
Distance between input shaft and differantial(mm):189.149
Length(mm):386.9
Width(mm):475.9
Height(mm):382
Weight(kg):38
Drive Form:FF
SOP: Yes
Utility Scope: mainly match with 1.6-ltr.or 2.0-ltr. gasoline engine and 1.3-ltr.TC diesel engine
Technical Data: Max. Input Torque(NM):230
Distance between input and output shaft(mm):78
Distance between final drive shaft(mm): 126
Distance between input shaft and differantial(mm):204
Length(mm):400
Width(mm):509.2
Height(mm):346
Weight(kg):46
Drive Form:FF
SOP: Yes
Utility Scope: mainly match with 372/472 engine
Technical Data: Max. Input Torque(NM):120
Distance between input and output shaft(mm):60
Distance between final drive shaft(mm):112
Distance between input shaft and differantial(mm):158.5
Length(mm):343.3
Width(mm):490
Height(mm):475
Weight(kg):25
Drive Form:FF
SOP: Yes
I looked up for the most powerful versions available.
Technical Data : Cylinder:6
Displacement:2.957
Name : 3.0L CBR VVT
Code : SQR684V
SOP : 2007.7
Emission: EU Ⅳ
Technical Data : Cylinder:4
Displacement:1.855
Code : SQR481B
SOP : 2007.08
Emission: EU Ⅳ
Only 125 kw(167 HP) and 146 kw(195 HP)?
Maybe acceptable in China, but totally unacceptable outside China.
1. you've missed out on the 144KW (approx.193BHP) 2.0L Engine.
2. That's right, all the cars outside of China must have 200BHP and above engines, where on earth are you from to have such deluded idea?
Not available until January 2008. In other word, a vaporware. Not to mention it probably can't meet the California emissions standard, which is more than twice as tough as Euro4.
The US market expects 170 HP from a naturally aspirated four banger and at least 240 HP from a V6 right now in 2006. Who knows what kind of hp that the industry majors will be delivering in 2009.
The 146KW 6 banger is currently scheduled to start production in July '07, make a comment on that, why don't you? (it will be much easier for you to be a bigger person and admit that you've missed out on the 144KW DGI 4 banger) And who are you to judge these engines might not pass CA emission standards when its time for them to be shipped over the pond? What is your basis?
[/QUOTE]The US market expects 170 HP from a naturally aspirated four banger and at least 240 HP from a V6 right now in 2006. Who knows what kind of hp that the industry majors will be delivering in 2009.[/QUOTE]
wow, I repeat: "where on earth are you from to have such deluded idea?" (this time I really want to know)
[/QUOTE]Maybe acceptable in China, but totally unacceptable outside China.[/QUOTE]
FYI: DO remember that there are countries other than the US and China. These ACTECO engines and Chery cars are not designed solely for the US market. You should really get out of the US and see the world more offen. (where you won't see so many pick-up trucks and minivans)
wow, I repeat: "where on earth are you from to have such deluded idea?" (this time I really want to know) ...at least give us the source of your claim.
I already did.
146 kw(195 HP)?
Turbos have a trouble meeting CA emissions standard.
From the catalogs of current mid-size cars sold in the US, like Camry, Accord, Sonata, Altima, etc.
Yea, like Africa, Egypt, Southeast Asia, etc.
41 - 60 of 90 Posts
