41 - 60 of 86 Posts
Chery Tiggo 5x (contd.)
This is the T19 with 1.5 naturally aspirated engine:
Note NDRC code, engine code, displacement and power output:
Torsion beam, semi-/non-independent suspension rear:
Dimensions:
J68/T17: 4338 x 1830 x 1645 mm
T19: 4358 x 1830 x 1670 mm
But what I mentioned about foreign markets holds true, i.e. that some countries are still getting the J68 with the original face.
Hi I've just purchased a 2022 Tiggo 4 Pro (5X) in Saudi Arabia. It has the latest 10 inch display, as fitted to the Tiggo 4 (5X), 7 & 8. the Tiggo 2 (3X) seems to have a slightly different version.
It is enabled with Chery Clouddrive, IOS carplay and Android Auto. AA has recently been added replacing QDlink. AA needs to be accessed via a cable and phone connection is via BT.
The system info says it's version is SW-02.04.00 HW-0.0.1. Are upgrades available anywhere?
Also does anyone know if it possible to get RDS info enabled on the radio. I noticed RDS works on the Tiggo 2 Pro (3x) when I test-drove one.
The owner's manual is pretty hopeless, it took me 2 hrs to work out how to change it from Arabic to English.
I have now worked out the basics of the system but need to know how to access the internal local storage? Does anyone know how to access the local storage or if there is a file manager app that will work with the system or AA?
I current have my phone connected to USB1, a flash drive with music / podcasts on USB2. Bluetooth storage is unavailable when phone connected via cable for AA
41 - 60 of 86 Posts
