i had scorpio before and i can compare these two cars, scorpio is hard worker car, especially with really good 4x4, you can drive it anywhere but main problem was big weight of vehicle, over 2t, also he is much smaller then hover, between 4,3, that diesel engine inside also like to spend fuel, if you drive it normaly under 100 km/h it spend between 10l, but all over...15l without problem, hover is always between 10-11 liters of gasoline fuel, but on some open roads you can very easy drive under 9 liters also, and on my car i have LPG sistem on it, you it's much chaper for drive, hover also have very good 4x4 sistem, almost the same like mahindra, but because of modern desing sometimes it's pitty to drive off road with such nice car
from inside, hover is much more comfortable, simply have more space and better seats, especially on rear seats, you can sleep there very easy
, also aerodinamics of hover and sterring sistem is much better, also my hover have abs and airbags, while mahindra didn't have nothing, i don't care about that so much, but sometimes it's good to have, in rear trunk you can put lot of goods in both car
interior of mahindra is very cheap with big buttons, while in hover plastic is little bit hard, i mean on touch, but it's good quality, didn't have any problem with is and nothing broke, also central console in hover is very easy to use, heating sistem, cd sistem and other...all is very easy to use, maybe it will be good that hover also have central computer display, i also drive new model of scorpio and still hover is much better to me, i will not say that mahindra is bad car, all depends what are your needs and expentation of car, if you need good family car with high off road skills and good performance on highway that you can use hover, if you need hard working car that you should pick mahindra
