1 - 20 of 109 Posts
Discussion Starter · #4 ·
thank you for your question
pokershark said:
does gonow have any plans to come to north america
Thank you for your words very much.
Of course my company want to explore north maerica,but you know the north of america's car market it is so rigorous,so it need some time for my company preparing.
But I am sure one day will come.
Discussion Starter · #5 ·
it is good question
pokershark said:
also do they have any sedans and coupes...i only seeing Minivans and minibuses and suvs' :(
Now my company is special in Minivans and PICK-UP,SUV vehicle,you know the automobile is not the same as other business,it need large money to invest,so only my company do well in these vehicles,then my company will make any others.
hello i m just curious
this question is for somebody who works at gonow, do you ship you cars or you just sell them in China? and by the way i m really impressed by the body and the interior. do you have specifications for the engine?
and your website doesnt work...you might want to check up on it.
thank you
How about the exporting your vehicles?
hello i would like to know if you offered exclusivity of car sales around the world to people , because i m interested in selling your car in africa especially west africa is it possible or the exclusivity is already taken?
thank you for letting me know
Discussion Starter · #14 ·
technical parameter
Vehicle(with gasoline engine)
Vehicle type GA1020regular double cabin pickup GA1020Lextralong double cabin pickup GA6490jetstar(SUV) GA6460victory(SUV)
Overall dimension(length×width×height) 5180×1690×1710 (mm) 5535×1690×1710 (mm) 5095×1780×1870/1940 (mm) 4590×1766×1837 (mm)
Size of inside cargo body 1480×1470×440(mm) 1835×1470×440(mm)
Track (front/Rear) 1445/1430(mm) 1445/1430(mm) 1480/1465(mm) 1480/1465(mm)
Wheel base 3025(mm) 3380(mm) 3025(mm) 2725(mm)
Min. ground clearance 185(mm) 185(mm) 185(mm) 185(mm)
Front/rear suspension 865/1290(mm) 865/1290(mm) 840/1230(mm) 862/1003(mm)
Kerb mass 1520(kg) 1580(kg) 1640(kg) 1571(kg)
Loading capacity 500(kg) 500(kg)
Max. vehicle weight 2345(kg) 2405(kg) 2105(kg) 2066(kg)
Seat capacity 5 5 5 5
Approach/ Departure angle 28°/18° 28°/18° 29°/26° 25°/24°
Top speed (Km/h) ≥120 ≥120 ≥120 ≥120
Fuel consumption ≤7.8(L/100km) ≤7.8(L/100km) ≤7.8(L/100km) ≤7.8(L/100km)
Driving type Rear wheel drive (4×2)
Engine GA491QE
Vehicle (with diesel engine)
Vehicle type GA1020CRegular double cabin pickup GA1020CLExtra long double cabin pickup GA6490C(SUV) GA6460C(SUV)
Overall dimension(length×width×height) 5155×1690×1710 (mm) 5510×1690×1710 (mm) 5095×1780×1870/1940 (mm) 4590×1766×1837 (mm)
Front/rear suspension 840/1290(mm) 840/1290(mm) 840/1230(mm) 862/1003(mm)
Engine 4JB1
Integral vehicle
Vehicle type GA1020(GA1020C) GA1020L(GA1020CL) GA6490 (GA6490C) GA6460(GA6460C)
Parameterof steeringsystem Min. turning diameter ≤12m ≤12m ≤12m ≤12m
Tracking in mm 0-2.00 0-2.00 0-2.00 0-2.00
Camber 30'± 45' 30'± 45' 30'± 45' 30'± 45'
Pivot angle 10°± 45' 10°± 45' 10°± 45' 10°± 45'
Trailing angle 1°± 45' 1°± 45' 1°± 45' 1°± 45'
Driving system and it’s parameter
tire type 215/75R15 215/75R15 235/75R15 235/75R15
Tire rim 6J 6J 6J 6J
Permitted tire rim 61/2J 61/2J 61/2J 61/2J
Wheel roll radius 349 349 365 365
tire 2 front tire,2 rear tire,1 spare tire
the tire pressures 280±30KPa(front), 280±30KPa(rear)
Wheel MAX corner ≥20°
Suspension type front Dual cross arm, torsion lever spring independent suspension
rear Graded rigidity, asymmetric leaf spring
Vehicle’s weight and brake system
Curb mass (kg) 1520 1580 1640 1571
front axle mass (kg) 870 885 770
rear axle mass (kg) 650 695 710
Gross weight (kg) 2345 2405 2105 2066
Permissible front axle load (kg) 950 985 870
Permissible rear axle load (kg) 1395 1420 1235
Permissible passenger quantity 5 5 5_7 5
Permissible load (kg) 500 500
Brake mode Double-tube vacuum servobrake
brake front Disc-type brake
rear Drum-type brake
Parking brake (hand brake) Rear wheel edge brake , central manual brake handle operation
Brake fluid type Synthesis brake fluid JG3 (GB10830-98)
Transmission system
Driving type 4×2
Clutch diaphragm spring, torsion vibration absorptive hydraumatic operation
Clutch pedal free range 12-36 mm
Clutch device fluid type Synthesis brake fluid JG3 (GB10830-98) or SAEJ1730/DOT3
Gearbox type 5 advance gears, 1 back gear, 5 gears timing
Name Tang-gear 5DYA4-3.2 Shang-gear JK72C8
Speed ratio first gear 4.452 4.452
second gear 2.398 2.398
third gear 1.414 1.414
fourth gear 1.000 1.000
fifth gear 0.802 0.802
sixth gear 4.4725 4.4725
Gear box lubrication oil type APIGL-4level gear oil, SAE90(summer), SAE80(winter)
Gear box gear lubrication oil capacity 2L
Driving axle Exposed, 2 section, intermediate support
Rear axle integral die stamping welding axle cover
Main moderating ratio 4.55
Rear axle lubrication oil type APIGL-5level
Rear axle lubrication oil capacity 1.8L
Electrical system and Power steering system
gasolineengine Wire joint mode Minus pole connect iron
Rated voltage 12V
Spark plug F6RT or F7TC
Starter 12V solenoid operated type
Generator Inner-adjust integral type silicon rectification generator, Minus pole connect iron, Rated voltage 14V, Rated current 90A
dieselengine Wire joint mode Minus pole connect iron
Rated voltage 12V
Generator Inner-adjust integral type silicon rectification generator, Minus pole connect iron, Rated voltage 14V, Rated current 65A
Power steering device Operate rotary valve, power cylinder, gear rack and gear fan, recirculating ball-type steering
Speed ratio 15.08
MAX working pressure 10MPa
Working flow 7-9L/min
Working oil DEXRON III or 8# hydramatic transmission oil
System capacity 1.0L
car selling in west africa
Dear sir,
i wouldn't be asking if i did not believe in the possibility for me to sell the vehicles, i've sold thousand of Ssangyong and daewoo cars. I understood that there is an agent. I have faith in the quality of your vehicles for driving one in Lebanon, so give me some news!:thumb:
Discussion Starter · #18 ·
Thank you very much for your interest my car
My friends,first thank you very much interest my cars.
Now my company's car has exported many countries,especial middle-east and north of africa,we also export many cars to Italy.
Though my car's quality could not better compare with Japanese car,our quality is improving every day.
If you have anything else about my car,please to send me email or call me.
best regards,
jason
My Company Will Like To Be Your Company Official Distributors In Nigeria.
Dear Sirs,
Ours is UPSOLO INTERNATIONAL COMPANY LIMITED, we located in Akure, the capital city of Ondo State, in the South western parts of Nigeria.
We are Auto marketing company distributing various cars since 1992. we have been importing various vehicles from Europe into Nigeria market since then, we are fast stock liquidating company with a very wide networking all over Nigeria.
We have no doubt in our mind that we are well able to promote your products in Nigeria market especially THE PICKUP. As a result we will like to be appointed as your OFFICIAL DISTRIBUTORS IN NIGERIA.
W shall be expecting your reply very soon.
Our address are: UPSOLO INTERNATIONAL COMPANY LIMITED, No 31 FANIBI ROAD, P.O. BOX 2517, AKURE, ONDO STATE, NIGERIA.
Tel: +234 34 243601
Fax: +234 34 241001
Mobile: +234 803 911 15 15
E-mail: [email protected]
MICHAEL SOLOMON
For Upsolo.Int.Co.Ltd
NIGERIA.
1 - 20 of 109 Posts
