Re: Anyone had any problems ?
today is 2010 and your hover is 2008 with 9065 km? what do you do with the car? keep it in garage whole year? or you buy a one year old new car which was on stock?
hover is little bit lazy in first 20000 km, simply the engine need that period to adopt and after that is goes much better, also i am wondering how you vehicles go so slow with couple of person inside, A/C don't have such huge impact on this car, because it have enough HP to carry it, by my opinion you should check your air,fuel filter and spark plug and replace them, becasue car have such low mileage i think that it was parked for very long time somewhere, i can't find any other explenation for such low mileage, hover like to be driver at high rpm, so don't bother to stick the throttle to "the end", simply hover like when you drive it like that
here is one sample:
my car have only 1 month and we do a first service to replace engine oil on 2500 km, on 7500 km i drive this car with full speed for over 200 km at local highway and nothing happend, this car now have over 100.000 without any engine problems and goes quite good for a 2ton suv, from the beggining you should drive this engine without much saving, simply japanese engines like high rpm :thumb:
for the vibrations, check the proppeler shaft and make a balance, or simply check the tires and balance them, keep the pressure between 2,3 on front and 2,5,2,6 on rear if you drive lot of persons there, i think that here is nothing serius, if still you have problem go to your service station to check the suspension but i don't think that there is any problem with it
