Sell SINOTRUK Trucks
5007 Views 6 Replies 2 Participants Last post by  SINOTRUK
We SINOTRUK are the biggest and best heavy-duty truck manufacturer in China. We can supply truck products as below.
* Brands: HOWO, STEYR KING, STEYR, HOKA, GOLDEN PRINCE, HOYUN, etc.
* Trucks: Tractor Trucks, CNG Tractor Trucks, Dump trucks/Tippers, Cargo Trucks, Concrete Mixer Trucks, Semi-Trailers, Bulk Cement Tankers, Water Tankers, Fuel Tankers, Fire Fighting Trucks, Other Specialized Vehicles, etc.
* Truck Spare Parts: Diesel Engines, Axles, Propeller Shafts, Transmissions, etc.
If you are interested in our products in any time, please let me know.
Contacts: Andy
Mail: china.sinotruk(at)gmail(dot)com;
MSN: sinotruk.china(at)hotmail(dot)com;
YIM: howosale(at)yahoo(dot)com;
Skype: sinotruk.china;
Web:www.sinotruk.com
Blog:http://sinotruk.wordpress.com/
1 - 7 of 7 Posts
hello andy
i sow your trucks many times, they look very attractive but i am intresred in following, do you have european homologation and euro 5 engines?
Hi Micodelija, Thanks for your reponse. At present, our trucks can be equipped with engine Euro 2 and Euro 3. We will have engine EURO 4 in the near future. Will inform you then.
Supply SINOTRUK HOWO 6X4 Tractor Truck
Model: ZZ4257S3241V
Drive Type: 6X4
Cab: HW79
Engine: SINOTRUK 371HP#2200 rpm; Euro II; 4 stroke direct injection diesel engine; 6 cylinder in-line with water cooling, turbo-charging & intercooling; Displacement: 9.726L
Gear Box: HW19710, 10 forward and 2 reverse
Steering: ZF8098, hydraulic steering with power assistance
Rear Axles: ST16, pressed axle housing, central single reduction with planetary wheel reduction (hub reduction), and different locks between wheels and axles
Tire: 12.00-20 (12.00R20 optional)
With: Safety belt
With: A/C
With: Two Bunks
we supply various dump trucks/tipper truck, tractor trucks, semi-trailers, cargo trucks, concrete mixer trucks, bulk cement tankers, water tankers, fuel tankers, garbage truck, fire fighting trucks, other specialized vehicles and their spare parts.
Contacts: Andy
Supply SINOTRUK HOWO 6X4 Tipper/Dump Truck
Model: ZZ3257N3847A
Engine: SINOTRUK 336HP Euro II at 2200 rpm; Euro II; 4 stroke direct injection diesel engine; 6 cylinder in-line with water cooling, turbo-charging & intercooling; Displacement: 9.726L
Drive Type: 6X4
Cabin: HW76
Transmission: HW15710, 10 forward and 2 reverse
Steering: ZF8098 hydraulic steering with power assistance
Rear Axles: HC16, pressed axle housing, central single reduction with planetary wheel reduction (hub reduction), and different locks between wheels and axles
Tires: 12.00-20 (12.00R20 optional)
With: Safety belt
With: A/C
With: Single Bunk
Body Inside Dimension (LXWXH)(mm): 5600X2300X1500(T Form)
Thickness of bottom plate/side plate (mm): 10/8(Thickness can be changed)
Contacts: Andy
Model: ZZ4257S3241V
Drive Type: 6X4
Cab: HW79
With: Safety belt
With: A/C
With: Two Bunks
Contacts:
Andy Wang
Email: china.sinotruk#gmail.com;
Supply SINOTRUK HOWO Tipper/Dump Truck
Model: ZZ3257N3847A
Drive Type: 6X4
Cabin: HW76
With: Safety belt
With: A/C
With: Single Bunk
Contacts: Andy
1 - 7 of 7 Posts
