SHANDONG BAOYA VEHICLE CO.,LTD. is a joint venture of two companies from Hong Kong and China mainland. The company locates in Jinan, the capital of Shandong Province, China. It has 5 subsidiary companies and OEM factories. It’s an export-oriented company, Its main products are Light Commercial Trucks, ATVS, Electric Cars, Tricycles and Auto Parts. Following the needs of different market and developing proper products are our policy from the date of foundation. Most of our products are for overseas market. Now the products have been export to over 50 countries around the world and welcomed by our customer with the fashion design and good performance and after sales service.
http://www.baoya-ev.com/cnindex.asp
Electric vehicles.
XFD600ZK
Tricycles
XF250ZK-3
Electric vehicles.
XFD600ZK
BYYICHI5000Dimension (L*W*H): 2608*1515*1526mm
Ground clearance: 110mm
Wheelbase: 1800mm
Max speed: 55 km/h (can be restricted below 40 km/h for EEC certificate)
Wheel type (front/rear): 155-80R12 77T / 155-80R12 77T
Brake distance: ≤6m
Net weight: 940kg (we are trying to slow down the weight to fit the request of EEC now)
Seating capacity: 2 persons
Turning radius: ≤4.6m
Grade ability: 13
Power: 48V DC 3KW/72V AC 6.5KW
Electric system: 12V DC
Battery: 12V 200Ah*6 lead-acid
Charger: 72V 25A
Controller: 72V
Charging time: ≤10h
Distance per charge: ≥130km
Speed control: Pedal control/automatic
Drive type: Rear wheel drive
Steering system: Rack-and-pinion steering gear
Parking brake: Hand/rear-wheel brake
Battery type: Lead-acid maintenance battery
Weight of battery: 384kg
Battery life: Recharging for 500 times
Container capacity: 5 units per 40'container
BY5000EV-1ADimension (L*W*H): 3350*1710*1465(mm)
Ground clearance: 150mm
Wheelbase: 1260mm
Max speed: 65km/h
Wheel type (front/rear): 145/70R12
Net weight: 750KG
Seating capacity: 4persons
Power: 72V DC 5kw
Battery: 72V 150AH lead-acid
Charger: 72V 25A
Controller: 72V
Distance per charge: ≥100km
Battery type: maintenance-free Lead-acid battery
Container capacity: 6 units per 40'container
Motor 4kw brush DC
Battery 4872V 120AH
Max torque 100Nm
Gear 2 speed
Drive system Front wheel drive
Maxspeed 55km/h
Max distance 100km
Climb ability 25°
Brake (F/R) Disc/disk
Charge time 8-10h
Total weight 750kg
Dimension L*W*H 2850*1790*1450mm
Wheelbase 1800mm
Tyre 155/65R13
Container capacity 8/40HC
Tricycles
XF250ZK-3
Engine type 1-cylinder,4-stroke water cooled
Bore/Stroke(mm) 67×65
Displacement 229.2
Max. power {kw/(r/min)} 12/6500
Ignition CDI
Clutch Wet, multiple plate
Overall dimensions LWH(mm) 2850*1350*1660
Max. Speed(Km/h) ≤85
Transmission Axle
Gearshift 5+1 speed, manually
Tire 5.00-10
